跳转到主内容
VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning
你所需要的
  1. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, Battery: 步骤 1 中的图像 1,2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, Battery: 步骤 1 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 2 中的图像 1,3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 2 中的图像 2,3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 2 中的图像 3,3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 3 中的图像 1,3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 3 中的图像 2,3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 3 中的图像 3,3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 4 中的图像 1,2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 步骤 4 中的图像 2,2
    • Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
  5. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 5 中的图像 1,3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 5 中的图像 2,3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 5 中的图像 3,3
    • Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
  6. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 6 中的图像 1,2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 6 中的图像 2,2
    • Remove two 7.2 mm screws with a Phillips #0 screwdriver.
    • Slide off the spring.
  7. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 7 中的图像 1,3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 7 中的图像 2,3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 7 中的图像 3,3
    • Remove the single 7.5mm screw with a Phillips #0 screwdriver.
    • Lift up the black plastic piece.
  8. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 8 中的图像 1,2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 8 中的图像 2,2
    • Remove four 7.5mm screws with a Phillips #0 screwdriver.
  9. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 9 中的图像 1,2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 9 中的图像 2,2
    • Remove the two buttons, noting how wires are placed for reassembly.
  10. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 10 中的图像 1,2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 10 中的图像 2,2
    • Lift the button board up and away to clear room for lifting the motherboard.
    • Tilt the assembly up but being wary that it is still attached to the front panel.
  11. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 11 中的图像 1,1
    • Slide the toothed slider towards you to remove.
  12. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 12 中的图像 1,1
    • To reassemble, align the two black lines together by moving the belt back and forth.
    • Once aligned reinsert the toothed slider at the exact point shown.
  13. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 13 中的图像 1,2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 13 中的图像 2,2
    • Lift the assembly to gain access to the connection point under the assembly.
  14. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 14 中的图像 1,2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 14 中的图像 2,2
    • Remove the two 7.5 mm screws with a Phillips #0 screwdriver.
  15. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: 步骤 15 中的图像 1,1
    • With the connector removed, clean both of the boxed sections with rubbing alcohol on a cotton swab. Allow a minute for the alcohol to dry before reassembling.
结论
3等其他人完成本指南。
Sean Webb
于09/04/15注册
384 声望
创作了2篇指南
团队
USF Tampa, Team 2-4, Sullivan Fall 2015 USF Tampa, Team 2-4, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G4
3 名成员
创作了12篇指南
5条评论
Before I attempt this: Does this address the problem of the touch screen no longer responding and the device playing the same sound repeatedly?
Lars Gilbert - 回复
Well, the answer to my own question is “no”.
Lars Gilbert - 回复
What if the unit is only 1 week old. Unlikely to be contact cleaning issues
Jason Chu - 回复
@larsgilbert did you find a fix to your problem? I have the same problem!
Dany - 回复
Regrettably, no.
Lars Gilbert -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 5,635
