跳转到主内容
VTech Spin and Learn Color Flashlight Red Ring Replacement
你所需要的
  1. VTech Spin and Learn Color Flashlight Red Ring Replacement, Battery Housing: 步骤 1 中的图像 1,2 VTech Spin and Learn Color Flashlight Red Ring Replacement, Battery Housing: 步骤 1 中的图像 2,2
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Red Ring Replacement, Red Ring: 步骤 2 中的图像 1,3 VTech Spin and Learn Color Flashlight Red Ring Replacement, Red Ring: 步骤 2 中的图像 2,3 VTech Spin and Learn Color Flashlight Red Ring Replacement, Red Ring: 步骤 2 中的图像 3,3
    • Locate the screw covering stickers on the side of the red ring. These two stickers will be slightly larger than the normal stickers. In this case it was a ladybug and a duck on opposite sides of the ring.
    • With a plastic opening tool, gently remove the stickers by prying around the edges. Be careful with these as you will want to reapply them later
  3. VTech Spin and Learn Color Flashlight Red Ring Replacement: 步骤 3 中的图像 1,3 VTech Spin and Learn Color Flashlight Red Ring Replacement: 步骤 3 中的图像 2,3 VTech Spin and Learn Color Flashlight Red Ring Replacement: 步骤 3 中的图像 3,3
    • Remove the two 8mm Phillips #0 screws from the screw channels found under the stickers in step one. This can be seen in the first photo if step 2.
    • Once the screws have been successfully removed, grasp one half of the ring and pull gently to separate it from the yellow housing. Repeat on the opposite side and the ring is disassembled.
结论
Nathaniel Troyer
于08/27/15注册
441 声望
创作了4篇指南
团队
USF Tampa, Team 2-6, Blackwell Fall 2015 USF Tampa, Team 2-6, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G6
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 10
总计 301
