跳转到主内容
VTech Safe And Sound DM221 Speaker Replacement
你所需要的
  1. VTech Safe And Sound DM221 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Remove the battery cover.
  2. VTech Safe And Sound DM221 Speaker Replacement: 步骤 2 中的图像 1,1
    • Unplug the battery from its connector and remove.
  3. VTech Safe And Sound DM221 Speaker Replacement: 步骤 3 中的图像 1,1
    • Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
  4. VTech Safe And Sound DM221 Speaker Replacement: 步骤 4 中的图像 1,1
    • Separate the back half of the device from the front using the metal spudger.
  5. VTech Safe And Sound DM221 Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
    • This will allow the removal of the silver handle.
  6. VTech Safe And Sound DM221 Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the “TALK” button to get access to remove the motherboard.
  7. VTech Safe And Sound DM221 Speaker Replacement: 步骤 7 中的图像 1,1
    • Push down on the antenna, located on the top of the motherboard.
  8. VTech Safe And Sound DM221 Speaker Replacement: 步骤 8 中的图像 1,1
    • Gently remove the motherboard away from the monitor.
    • Be careful not to disconnect the red wire.
  9. VTech Safe And Sound DM221 Speaker Replacement: 步骤 9 中的图像 1,1
    • Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
结论
Krystal
于10/01/15注册
600 声望
创作了5篇指南
团队
USF Tampa, Team 1-5, Leahy Fall 2015 USF Tampa, Team 1-5, Leahy Fall 2015 的会员
USFT-LEAHY-F15S1G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 337
