跳转到主内容
VTech Safe And Sound DM221 Buttons Replacement
你所需要的
  1. VTech Safe And Sound DM221 Buttons Replacement, Buttons: 步骤 1 中的图像 1,1
    • Remove the battery cover by sliding it down.
  2. VTech Safe And Sound DM221 Buttons Replacement: 步骤 2 中的图像 1,1
    • Firmly grasp the battery and pull to disconnect the battery from its connector.
  3. VTech Safe And Sound DM221 Buttons Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #00 screwdriver, unscrew the two 5.0 mm screws located at the bottom of the monitor inside of the device.
  4. VTech Safe And Sound DM221 Buttons Replacement: 步骤 4 中的图像 1,1
    • Using a plastic opening tool, pry apart the front part of the device from the back. There are many access points, but the best spot to insert the spudger is around the "TALK" button.
    • Avoid using the metal spudger. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  5. VTech Safe And Sound DM221 Buttons Replacement: 步骤 5 中的图像 1,2 VTech Safe And Sound DM221 Buttons Replacement: 步骤 5 中的图像 2,2
    • Remove the buttons from the front part of the device.
    • Tip: The buttons on the front of the device (“POWER,” “SELECT,” “MENU,” “VOLUME”) are all connected as one unit. Pull them out carefully.
结论
Krystal
于10/01/15注册
600 声望
创作了5篇指南
团队
USF Tampa, Team 1-5, Leahy Fall 2015 USF Tampa, Team 1-5, Leahy Fall 2015 的会员
USFT-LEAHY-F15S1G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 362
