简介
Is your antenna not picking up the monitor signal? Read this repair guide to find out how to replace your antenna.
你所需要的
Remove the battery cover by sliding it down.
Firmly grasp the battery and pull to disconnect the battery from its connector.
Using a Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws located at the bottom of the monitor inside of the device.
结论
1指南评论
Great tutorial thanks! What type of antenna should I replace it with to get better reception?
