跳转到主内容
修复你的物品
维修的权力
商店
简介
Prerequisite Only
配件
没有特定配件。
  1. Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device. Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
    • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
    • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
  2. Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down. Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
    • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
    • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
结论
Johnnie Cairns
于2016年02月10日注册
495 信誉积分
创作了4篇指南
团队
USF Tampa, Team 2-6, Sullivan Spring 2016 USF Tampa, Team 2-6, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G6
3 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 70
