跳转到主内容
VTech Learning Tunes Karaoke Power Button Replacement
你所需要的
  1. VTech Learning Tunes Karaoke Power Button Replacement, Power Button: 步骤 1 中的图像 1,1
    • To remove the battery door, loosen the 4mm screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw
  2. VTech Learning Tunes Karaoke Power Button Replacement: 步骤 2 中的图像 1,2 VTech Learning Tunes Karaoke Power Button Replacement: 步骤 2 中的图像 2,2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Power Button Replacement: 步骤 3 中的图像 1,1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Power Button Replacement: 步骤 4 中的图像 1,2 VTech Learning Tunes Karaoke Power Button Replacement: 步骤 4 中的图像 2,2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Power Button Replacement: 步骤 5 中的图像 1,1
    • Remove four 7.9 mm screws from the mode selector and voice selector trays.
  6. VTech Learning Tunes Karaoke Power Button Replacement: 步骤 6 中的图像 1,1
    • Remove the two 5.6 mm screws from the power button board.
  7. VTech Learning Tunes Karaoke Power Button Replacement: 步骤 7 中的图像 1,1
    • Carefully move the power button board out of the way.
    • From here you can replace the button.
结论
团队
USF Tampa, Team 7-2, Cheng Spring 2016 USF Tampa, Team 7-2, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G2
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 525
