跳转到主内容
VTech Kidizoom Smartwatch DX2 Speakers Replacement
你所需要的
  1. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Master Switch: 步骤 1 中的图像 1,2 VTech Kidizoom Smartwatch DX2 Speakers Replacement, Master Switch: 步骤 1 中的图像 2,2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 2 中的图像 1,2 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 2 中的图像 2,2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 3 中的图像 1,2 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 3 中的图像 2,2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 4 中的图像 1,3 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 4 中的图像 2,3 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 4 中的图像 3,3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 6 中的图像 1,2 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 7 中的图像 1,2 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 步骤 7 中的图像 2,2
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Speakers: 步骤 8 中的图像 1,1
    • Carefully desolder the speaker from the board.
    • Be careful to not desolder the battery cable.
结论
Jessica Richard
于10/25/18注册
512 声望
创作了4篇指南
团队
UMass Dartmouth, Team S3-G5, Peak Fall 2018 UMass Dartmouth, Team S3-G5, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G5
4 名成员
创作了7篇指南
一条评论
hi, where did you buy the spare speaker?
minhhai79 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 735
