跳转到主内容
VTech Kidizoom Smartwatch DX2 Faceplate Replacement
你所需要的
  1. VTech Kidizoom Smartwatch DX2 Faceplate Replacement, Faceplate: 步骤 1 中的图像 1,1
    • In order to remove the faceplate you must start by placing the watch screen upwards.
  2. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: 步骤 2 中的图像 1,1
    • Use iFixit’s opening tool, another similar tool, or simply use your fingernail to gently pry open the faceplate away from the screen starting from an edge.
    • You may hear a popping sound, but this is normal.
  3. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: 步骤 3 中的图像 1,1
    • Once successful, pull the remaining faceplate off from the watch.
结论
另外一个人完成了本指南。
Jessica Richard
于10/25/18注册
512 声望
创作了4篇指南
团队
UMass Dartmouth, Team S3-G5, Peak Fall 2018 UMass Dartmouth, Team S3-G5, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G5
4 名成员
创作了7篇指南
4条评论
Where can I find a faceplate?
Sammi Schummer - 回复
Where can you buy a replacement face plate?
Natalie - 回复
This doesn't remove the faceplate, just the decorative bezel around the screen. I'm looking for disassembly instructions to open up the screen as my son wore his I to the pool (immediately after being told not to! Kids…)
Jack Wesselo - 回复
Where can I get a replacement faceplate please
Steph Crowe - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 22
总计 2,538
