跳转到主内容
VTech Kidizoom Camera Connect Front Case Replacement
你所需要的
  1. VTech Kidizoom Camera Connect Front Case Replacement, Front Case: 步骤 1 中的图像 1,2 VTech Kidizoom Camera Connect Front Case Replacement, Front Case: 步骤 1 中的图像 2,2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Front Case Replacement: 步骤 2 中的图像 1,2 VTech Kidizoom Camera Connect Front Case Replacement: 步骤 2 中的图像 2,2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Front Case Replacement: 步骤 3 中的图像 1,3 VTech Kidizoom Camera Connect Front Case Replacement: 步骤 3 中的图像 2,3 VTech Kidizoom Camera Connect Front Case Replacement: 步骤 3 中的图像 3,3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Front Case Replacement: 步骤 4 中的图像 1,1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
结论
另外一个人完成了本指南。
Nick Foster
于02/14/16注册
288 声望
撰写一个指南
团队
USF Tampa, Team 6-4, Eyestone Spring 2016 USF Tampa, Team 6-4, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S6G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 42
总计 4,098
