跳转到主内容
简介
Exercise caution when soldering the speaker to and from the motherboard, as you could possibly melt the motherboard. This replacement is one of the most difficult, as it requires expertise with a soldering iron and a steady hand.
  1. Make sure that the master power switch is set to the (O) position.
    • Make sure that the master power switch is set to the (O) position.
  2. Using a plastic opening tool, gently pry off the circular plating over the camera lens.
    • Using a plastic opening tool, gently pry off the circular plating over the camera lens.
    • The circular plating is held by a mild adhesive. It will not be necessary to replace this adhesive during the reassembly process.
    • Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
    • Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
    • As there will be many screws being removed from the device, we recommend using a magnetic device such as the iFixit Magnetic Project Mat.
  3. Pry off the transparent plating and paper design using a plastic opening tool.
    • Pry off the transparent plating and paper design using a plastic opening tool.
  4. Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a  #0 screwdriver.
    • Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a #0 screwdriver.
  5. Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
    • Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
  6. Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon. Exercise caution while performing this step, as any excessive pulling may tear the connector ribbon from the motherboard. Exercise caution while performing this step, as any excessive pulling may tear the connector ribbon from the motherboard.
    • Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon.
    • Exercise caution while performing this step, as any excessive pulling may tear the connector ribbon from the motherboard.
  7. Use the soldering iron to reheat the solder around the speakers' prongs on the motherboard.
    • Use the soldering iron to reheat the solder around the speakers' prongs on the motherboard.
    • Be Careful of very high temperatures when using the soldering iron.
    • The soldering iron may melt the motherboard if contact is made.
  8. Pry the speaker off  the motherboard using a plastic opening tool.
    • Pry the speaker off the motherboard using a plastic opening tool.
    • Prongs may still be hot from soldering.
结论
Anthony Teresi
于2016年02月10日注册
587 信誉积分
创作了4篇指南
团队
USF Tampa, Team 3-5, Sullivan Spring 2016 USF Tampa, Team 3-5, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S3G5
3 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 3
总计 219
