跳转到主内容
加入维修社区 - 创建账户
VTech InnoTab Max Screen Replacement
你所需要的
    1. VTech InnoTab Max Screen Replacement, Cover: 步骤 1 中的图像 1,3 VTech InnoTab Max Screen Replacement, Cover: 步骤 1 中的图像 2,3 VTech InnoTab Max Screen Replacement, Cover: 步骤 1 中的图像 3,3
      • Remove all screw caps from the back panel using a metal spudger.
      询问修复机器人
      添加评论
    2. VTech InnoTab Max Screen Replacement: 步骤 2 中的图像 1,3 VTech InnoTab Max Screen Replacement: 步骤 2 中的图像 2,3 VTech InnoTab Max Screen Replacement: 步骤 2 中的图像 3,3
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      添加评论
    3. VTech InnoTab Max Screen Replacement: 步骤 3 中的图像 1,2 VTech InnoTab Max Screen Replacement: 步骤 3 中的图像 2,2
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      询问修复机器人
      添加评论
    4. VTech InnoTab Max Screen Replacement: 步骤 4 中的图像 1,2 VTech InnoTab Max Screen Replacement: 步骤 4 中的图像 2,2
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      询问修复机器人
      添加评论
    1. VTech InnoTab Max Screen Replacement, Battery: 步骤 5 中的图像 1,1
      • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
      询问修复机器人
      添加评论
    2. VTech InnoTab Max Screen Replacement: 步骤 6 中的图像 1,3 VTech InnoTab Max Screen Replacement: 步骤 6 中的图像 2,3 VTech InnoTab Max Screen Replacement: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
      • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
      • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
      添加评论
    3. VTech InnoTab Max Screen Replacement: 步骤 7 中的图像 1,3 VTech InnoTab Max Screen Replacement: 步骤 7 中的图像 2,3 VTech InnoTab Max Screen Replacement: 步骤 7 中的图像 3,3
      • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
      询问修复机器人
      添加评论
    4. VTech InnoTab Max Screen Replacement: 步骤 8 中的图像 1,1
      • The battery is now fully disconnected.
      添加评论
    1. VTech InnoTab Max Screen Replacement, Screen: 步骤 9 中的图像 1,2 VTech InnoTab Max Screen Replacement, Screen: 步骤 9 中的图像 2,2
      • In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
      • To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
      询问修复机器人
      添加评论
    2. VTech InnoTab Max Screen Replacement: 步骤 10 中的图像 1,3 VTech InnoTab Max Screen Replacement: 步骤 10 中的图像 2,3 VTech InnoTab Max Screen Replacement: 步骤 10 中的图像 3,3
      • Once the pins are removed the screen should be loose from the frame and only connected by the brown film pictured.
      询问修复机器人
      添加评论
    3. VTech InnoTab Max Screen Replacement: 步骤 11 中的图像 1,3 VTech InnoTab Max Screen Replacement: 步骤 11 中的图像 2,3 VTech InnoTab Max Screen Replacement: 步骤 11 中的图像 3,3
      在这个步骤中使用的工具:
      • In order to completely remove the screen you need to unclip the film from the motherboard by simply using a pair of tweezers and gently pulling.
      • Be careful not to tear the film when pulling.
      询问修复机器人
      添加评论
    4. VTech InnoTab Max Screen Replacement: 步骤 12 中的图像 1,2 VTech InnoTab Max Screen Replacement: 步骤 12 中的图像 2,2
      • Once unclipped from the motherboard the screen should be entirely free from the device
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
USF Tampa, Team S5-G5, Lacy Spring 2017 USF Tampa, Team S5-G5, Lacy Spring 2017 的会员
USFT-LACY-S17S5G5
3 名成员
创作了15篇指南
5指南评论
Where can I buy a screen
Damien Hennigan - 回复 分享
Where can I buy a screen? Can't find any sites that sell the innotab Max screens.
i can not seem to find a replacement screen online, where can i buy one? Innotab Max from Vtech… HELP please..
fanny_muller - 回复 分享
Hello, where can i buy a KIDICOM MAX Rose Screen. Our daughter here is broken!.thanks a lot!
hans.depre@gmail.com
Hans Depre - 回复 分享
bonjour je cherche a raplasser l ecran du kidicom max car le mien ne salume plus pas merci
theobald - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 31
总计 5,860
