跳转到主内容
VTech InnoTab Max Battery Replacement
你所需要的
  1. VTech InnoTab Max Battery Replacement, Cover: 步骤 1 中的图像 1,3 VTech InnoTab Max Battery Replacement, Cover: 步骤 1 中的图像 2,3 VTech InnoTab Max Battery Replacement, Cover: 步骤 1 中的图像 3,3
    • Remove all screw caps from the back panel using a metal spudger.
  2. VTech InnoTab Max Battery Replacement: 步骤 2 中的图像 1,3 VTech InnoTab Max Battery Replacement: 步骤 2 中的图像 2,3 VTech InnoTab Max Battery Replacement: 步骤 2 中的图像 3,3
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
  3. VTech InnoTab Max Battery Replacement: 步骤 3 中的图像 1,2 VTech InnoTab Max Battery Replacement: 步骤 3 中的图像 2,2
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
  4. VTech InnoTab Max Battery Replacement: 步骤 4 中的图像 1,2 VTech InnoTab Max Battery Replacement: 步骤 4 中的图像 2,2
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
  5. VTech InnoTab Max Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
  6. VTech InnoTab Max Battery Replacement: 步骤 6 中的图像 1,3 VTech InnoTab Max Battery Replacement: 步骤 6 中的图像 2,3 VTech InnoTab Max Battery Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
    • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
    • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
  7. VTech InnoTab Max Battery Replacement: 步骤 7 中的图像 1,3 VTech InnoTab Max Battery Replacement: 步骤 7 中的图像 2,3 VTech InnoTab Max Battery Replacement: 步骤 7 中的图像 3,3
    • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
  8. VTech InnoTab Max Battery Replacement: 步骤 8 中的图像 1,1
    • The battery is now fully disconnected.
结论
8等其他人完成本指南。
Jacob Schioppo
于02/15/17注册
594 声望
创作了4篇指南
团队
USF Tampa, Team S5-G5, Lacy Spring 2017 USF Tampa, Team S5-G5, Lacy Spring 2017 的会员
USFT-LACY-S17S5G5
3 名成员
创作了10篇指南
10指南评论
Thank you for the useful guide!
Which battery (exact specs) can be used as a replacement?
kermit - 回复
Where can we purchase a replacement battery
Frank Godon - 回复
Where can we buy a replacement battery
Frank Godon - 回复
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
Donald Josefczyk - 回复
Since it seems like a replacement battery cannot be purchased anywhere, can the battery be bypassed to still use it plugged in? I know it defeats the purpose of a tablet, but it would be nice to still use it. Anyone have suggestions?
ktmm - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 78
总计 15,307
