当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Lift the Leg all the way up and twist the bottom to remove.
Once the bottom part pops out the whole leg should just come off.
Remove any game cartridge from the device.
Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
These covers are made of hard plastic so they may be difficult to remove.
There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
Using a plastic opening tool, detach the backplate from the front piece.
Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
Once the backplate has been removed, you will have access to the circuit board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
