跳转到主内容
加入维修社区 - 创建账户
VTech InnoTab 2S Headphone Jack Replacement
你所需要的
  1. VTech InnoTab 2S Headphone Jack Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2S Headphone Jack Replacement: 步骤 2 中的图像 1,2 VTech InnoTab 2S Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2S Headphone Jack Replacement: 步骤 3 中的图像 1,3 VTech InnoTab 2S Headphone Jack Replacement: 步骤 3 中的图像 2,3 VTech InnoTab 2S Headphone Jack Replacement: 步骤 3 中的图像 3,3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2S Headphone Jack Replacement: 步骤 4 中的图像 1,2 VTech InnoTab 2S Headphone Jack Replacement: 步骤 4 中的图像 2,2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2S Headphone Jack Replacement: 步骤 5 中的图像 1,2 VTech InnoTab 2S Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2S Headphone Jack Replacement, Motherboard: 步骤 6 中的图像 1,1
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2S Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2S Headphone Jack Replacement: 步骤 8 中的图像 1,1
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2S Headphone Jack Replacement: 步骤 9 中的图像 1,1
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2S Headphone Jack Replacement: 步骤 10 中的图像 1,1
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
  11. VTech InnoTab 2S Headphone Jack Replacement, Headphone Jack: 步骤 11 中的图像 1,1
    • First use the solderer tool to desolder the two points boxed in red on the image.
  12. VTech InnoTab 2S Headphone Jack Replacement: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    • Flip over the circuit board.
    • Using the metal tweezers, firmly grasp the headphone jack on either side and pull up to remove.
结论
Esthevan Romeiro
于10/06/16注册
261 声望
创作了4篇指南
团队
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016 的会员
USFT-LACY-F16S5G1
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 13
总计 347
