跳转到主内容
VTech InnoTab 2 Back Panel Replacement
你所需要的
  1. VTech InnoTab 2 Back Panel Replacement, Battery: 步骤 1 中的图像 1,3 VTech InnoTab 2 Back Panel Replacement, Battery: 步骤 1 中的图像 2,3 VTech InnoTab 2 Back Panel Replacement, Battery: 步骤 1 中的图像 3,3
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
  2. VTech InnoTab 2 Back Panel Replacement, Back Panel: 步骤 2 中的图像 1,3 VTech InnoTab 2 Back Panel Replacement, Back Panel: 步骤 2 中的图像 2,3 VTech InnoTab 2 Back Panel Replacement, Back Panel: 步骤 2 中的图像 3,3
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
  3. VTech InnoTab 2 Back Panel Replacement: 步骤 3 中的图像 1,3 VTech InnoTab 2 Back Panel Replacement: 步骤 3 中的图像 2,3 VTech InnoTab 2 Back Panel Replacement: 步骤 3 中的图像 3,3
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  4. VTech InnoTab 2 Back Panel Replacement: 步骤 4 中的图像 1,2 VTech InnoTab 2 Back Panel Replacement: 步骤 4 中的图像 2,2
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
  5. VTech InnoTab 2 Back Panel Replacement: 步骤 5 中的图像 1,2 VTech InnoTab 2 Back Panel Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
结论
Roberto Valdes
于10/18/17注册
302 声望
创作了3篇指南
团队
USF Tampa, Team S1-G85, Cagle Fall 2017 USF Tampa, Team S1-G85, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G85
2 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 10
总计 566
