跳转到主内容
VTech CS6719-2 Circuit Board Replacement
你所需要的
  1. VTech CS6719-2 Circuit Board Replacement, Battery: 步骤 1 中的图像 1,2 VTech CS6719-2 Circuit Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Unplug the battery input cable.
  4. VTech CS6719-2 Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Circuit Board Replacement, Circuit Board: 步骤 5 中的图像 1,2 VTech CS6719-2 Circuit Board Replacement, Circuit Board: 步骤 5 中的图像 2,2
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Circuit Board Replacement: 步骤 7 中的图像 1,2 VTech CS6719-2 Circuit Board Replacement: 步骤 7 中的图像 2,2
    • Remove the two 9mm screws located inside the back cover at the top.
结论
3等其他人完成本指南。
Benjamin Field
于02/08/16注册
270 声望
创作了2篇指南
团队
IUPUI, Team 1-4, Baechle Spring 2016 IUPUI, Team 1-4, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S1G4
4 名成员
创作了16篇指南
1指南评论
Thanks! Had to clean honey out if the speaker. Should Note the plastic quality is soft and can mark easily.
Jason Bellchamber - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 650
