跳转到主内容
VTech Baby's Learning Laptop Mode Switch Replacement
你所需要的
  1. VTech Baby's Learning Laptop Mode Switch Replacement, Battery and Rear Panel: 步骤 1 中的图像 1,1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 2 中的图像 1,1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 4 中的图像 1,2 VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 4 中的图像 2,2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: 步骤 5 中的图像 1,2 VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: 步骤 5 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
  6. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 6 中的图像 1,3 VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 6 中的图像 2,3 VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 6 中的图像 3,3
    • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
    • Lay the board down gently and out of the way.
    • Take care not to damage any of the wires or the board itself.
  7. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 7 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
    • Five 7.3mm
    • Two 6.0mm
  8. VTech Baby's Learning Laptop Mode Switch Replacement: 步骤 8 中的图像 1,1
    • Once the screws have been removed, the mode switch assembly can be removed easily.
    • Take care not to misplace the spring indicated in the picture.
    • You need this spring to find a matching replacement if it is in anyway damaged.
结论
团队
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 438
