跳转到主内容
VTech Baby's Learning Laptop Battery and Rear Panel Replacement
你所需要的
  1. VTech Baby's Learning Laptop Battery and Rear Panel Replacement, Battery and Rear Panel: 步骤 1 中的图像 1,1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Battery and Rear Panel Replacement: 步骤 2 中的图像 1,1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Battery and Rear Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Battery and Rear Panel Replacement: 步骤 4 中的图像 1,2 VTech Baby's Learning Laptop Battery and Rear Panel Replacement: 步骤 4 中的图像 2,2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G2
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 14
总计 1,109
