跳转到主内容
VTech Baby's Learning Laptop Speaker Replacement
你所需要的
  1. VTech Baby's Learning Laptop Speaker Replacement, Battery and Rear Panel: 步骤 1 中的图像 1,1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Speaker Replacement: 步骤 4 中的图像 1,2 VTech Baby's Learning Laptop Speaker Replacement: 步骤 4 中的图像 2,2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 VTech Baby's Learning Laptop Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Use a Phillips #0 screwdriver to unscrew the two 6.0 mm screws on the speaker.
  6. VTech Baby's Learning Laptop Speaker Replacement: 步骤 6 中的图像 1,2 VTech Baby's Learning Laptop Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the two 6 mm screws from the device.
    • Remove the speaker.
    • Be careful not to damage the wiring.
结论
Jordan Smith
于09/03/15注册
210 声望
创作了2篇指南
团队
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G2
4 名成员
创作了14篇指南
2条评论
Where to buy the replacement speaker
hadbuckley - 回复
Where can you buy the replacement speaker please. I live in Sydney Australia
hadbuckley - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 23
总计 1,239
