跳转到主内容
VENSTAR Taco Microphone Replacement Replacement
你所需要的
  1. VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: 步骤 1 中的图像 1,3 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: 步骤 1 中的图像 2,3 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: 步骤 1 中的图像 3,3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. VENSTAR Taco Microphone Replacement Replacement: 步骤 2 中的图像 1,2 VENSTAR Taco Microphone Replacement Replacement: 步骤 2 中的图像 2,2
    • Repeat the previous step on the opposite side to remove the other outer casing.
  3. VENSTAR Taco Microphone Replacement Replacement: 步骤 3 中的图像 1,2 VENSTAR Taco Microphone Replacement Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Phillips #0 Screwdriver
    $5.49
    购买
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  4. VENSTAR Taco Microphone Replacement Replacement: 步骤 4 中的图像 1,2 VENSTAR Taco Microphone Replacement Replacement: 步骤 4 中的图像 2,2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  5. VENSTAR Taco Microphone Replacement Replacement: 步骤 5 中的图像 1,2 VENSTAR Taco Microphone Replacement Replacement: 步骤 5 中的图像 2,2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
  6. VENSTAR Taco Microphone Replacement Replacement, Logic Board Replacement: 步骤 6 中的图像 1,1
    • Remove the rubber covering from the buttons.
  7. VENSTAR Taco Microphone Replacement Replacement: 步骤 7 中的图像 1,3 VENSTAR Taco Microphone Replacement Replacement: 步骤 7 中的图像 2,3 VENSTAR Taco Microphone Replacement Replacement: 步骤 7 中的图像 3,3
    • Remove the black fabric covering the logic board.
  8. VENSTAR Taco Microphone Replacement Replacement: 步骤 8 中的图像 1,2 VENSTAR Taco Microphone Replacement Replacement: 步骤 8 中的图像 2,2
    • Move the battery out of the way of the connector.
  9. VENSTAR Taco Microphone Replacement Replacement: 步骤 9 中的图像 1,2 VENSTAR Taco Microphone Replacement Replacement: 步骤 9 中的图像 2,2
    • Undo the connector of the flat white ribbon between the switches and the logic board.
  10. VENSTAR Taco Microphone Replacement Replacement: 步骤 10 中的图像 1,1
    • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
  11. VENSTAR Taco Microphone Replacement Replacement: 步骤 11 中的图像 1,3 VENSTAR Taco Microphone Replacement Replacement: 步骤 11 中的图像 2,3 VENSTAR Taco Microphone Replacement Replacement: 步骤 11 中的图像 3,3
    • Gently pull out the logic board.
    • Note that the battery and the logic board are connected and must be removed together.
  12. VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: 步骤 12 中的图像 1,2 VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: 步骤 12 中的图像 2,2
    • Below the logic board, the small black microphone is resting within the case.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 190
