简介
There is no visible way to open this device. Knowing this, assembly and disassembly must be done carefully in order to maintain the integrity of the device.
你所需要的
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
在这个步骤中使用的工具:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
即将完成!
结论
