跳转到主内容
Using a Floor Jack
你所需要的
  1. Using a Floor Jack, Using a Floor Jack: 步骤 1 中的图像 1,2 Using a Floor Jack, Using a Floor Jack: 步骤 1 中的图像 2,2
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
  2. Using a Floor Jack, Using floor jack to lift car.: 步骤 2 中的图像 1,1
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
  3. Using a Floor Jack: 步骤 3 中的图像 1,1
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
  4. Using a Floor Jack: 步骤 4 中的图像 1,1
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
结论
8等其他人完成本指南。
Shaun MacDonald
于10/03/12注册
2,558 声望
创作了8篇指南
团队
Cal Poly, Team 24-27, Regan Fall 2012 Cal Poly, Team 24-27, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G27
4 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 56
过去 30 天: 217
总计 40,013
