跳转到主内容
Upper Board Removal
你所需要的
  1. Upper Board Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 1 中的图像 1,1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Upper Board Removal: 步骤 2 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Upper Board Removal: 步骤 3 中的图像 1,3 Upper Board Removal: 步骤 3 中的图像 2,3 Upper Board Removal: 步骤 3 中的图像 3,3
    • Grab the top shell of the mouse and lift up to remove.
  4. Upper Board Removal: 步骤 4 中的图像 1,1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Upper Board Removal: 步骤 5 中的图像 1,2 Upper Board Removal: 步骤 5 中的图像 2,2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
  6. Upper Board Removal, Top Shell: 步骤 6 中的图像 1,1
    • Remove the 5 mm round head screw holding the middle piece to the top piece.
    • The outermost shell will now separate from the middle structure.
  7. Upper Board Removal, Upper Board: 步骤 7 中的图像 1,1
    • Using the Phillips #1 screwdriver, unscrew the 5 mm black flat head screw that's securing the scroll wheel cage.
  8. Upper Board Removal: 步骤 8 中的图像 1,2 Upper Board Removal: 步骤 8 中的图像 2,2
    • Pinch the cage to release snaps. You can now pull the cage off.
  9. Upper Board Removal: 步骤 9 中的图像 1,1
    • Remove the screw holding the circuit board down.
    • The board will now pop off easily.
结论
2等其他人完成本指南。
David
于01/16/13注册
1,181 声望
创作了4篇指南
团队
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G36
3 名成员
创作了30篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 16
总计 845
