跳转到主内容
Upgrading the Lenovo ThinkPad T520 Display
你所需要的
  1. Upgrading the Lenovo ThinkPad T520 Display, Contrasty Colors: 步骤 1 中的图像 1,1
    • This voids your warranty!
    • The exact original model used by Lenovo is the AUO B156HW01 V.4. This is a 15.6", matte, 1080p panel with wider than average viewing angles.
    • This display has been measured by notebookcheck.net and anandtech.com and shown to be one of the best laptop displays shipping.
    • A contrast ratio over 500 is available and this display is able to show over 95% of the colors in the AdobeRGB spectrum. 1080p is a much higher resolution than the basic 1366x768 display, allowing for more work space.
    • Viewing angle image courtesy of notebookcheck.net
  2. Upgrading the Lenovo ThinkPad T520 Display, OEM Matte: 步骤 2 中的图像 1,1
    • The V.4 display we will be using for this upgrade is the highest quality drop in replacement available and the exact same product that Lenovo uses. This version is a matte display with a "42% haze" AR coating.
    • The V.4 is slightly more reflective than the basic T520 display. The B156HW01 V.4 on the left makes a more focused reflection of the overhead light while the stock display (LG LP156WH4) creates a larger diffused reflection.
    • The manufacturer of this panel is AU Optronics, a multibillion dollar Taiwanese company that specializes in TFT LCD technology. Lenovo uses AUO displays but LCD resellers are also able to get boxes of panels that are sold for DIY upgrades and repairs.
  3. Upgrading the Lenovo ThinkPad T520 Display, Unboxing: 步骤 3 中的图像 1,3 Upgrading the Lenovo ThinkPad T520 Display, Unboxing: 步骤 3 中的图像 2,3 Upgrading the Lenovo ThinkPad T520 Display, Unboxing: 步骤 3 中的图像 3,3
    • This is how my upgrade display arrived from laptopscreen.com
    • It was shipped from Burnaby, British Columbia on the other side of Canada and arrived in three days.
  4. Upgrading the Lenovo ThinkPad T520 Display: 步骤 4 中的图像 1,3 Upgrading the Lenovo ThinkPad T520 Display: 步骤 4 中的图像 2,3 Upgrading the Lenovo ThinkPad T520 Display: 步骤 4 中的图像 3,3
    • The display uses the same 40 pin connector as the T520 and many other laptops. It provides power for the LED backlighting and the 1080p video signal.
    • A protective sheet is taped to the front of the display. Leave it on until we are almost done installing the display in the laptop.
  5. Upgrading the Lenovo ThinkPad T520 Display, Teardown: 步骤 5 中的图像 1,2 Upgrading the Lenovo ThinkPad T520 Display, Teardown: 步骤 5 中的图像 2,2
    • The victim. Any T520 will work with this upgrade. Even the most basic configurations can take advantage of a top of the line display. The Thinkpad T510, W510, T520, W520, T530 and W530 will all also work for this upgrade.
    • The first step is to remove the three covers along the bottom of the bezel and the screws underneath. The point of an exacto knife works well for this.
    • Three adhesive covers.
    • Three 6mm Phillips screws.
  6. Upgrading the Lenovo ThinkPad T520 Display, Bezel: 步骤 6 中的图像 1,3 Upgrading the Lenovo ThinkPad T520 Display, Bezel: 步骤 6 中的图像 2,3 Upgrading the Lenovo ThinkPad T520 Display, Bezel: 步骤 6 中的图像 3,3
    • Starting from the bottom of the screen, release the plastic clips holding the bezel by pushing horizontally inward and prying upward with a spudger.
  7. Upgrading the Lenovo ThinkPad T520 Display, Lid: 步骤 7 中的图像 1,3 Upgrading the Lenovo ThinkPad T520 Display, Lid: 步骤 7 中的图像 2,3 Upgrading the Lenovo ThinkPad T520 Display, Lid: 步骤 7 中的图像 3,3
    • The back of the display assembly is held to the metal frame with four screws that must be removed.
    • Carefully rotate the hinges upward just enough to allow the removal of the four screws on the sides of the display frame.
    • Be careful of the cable for the magnetic lid close sensor. You may need to temporarily unstick the sensor from the frame or pull on the cable a bit to make it extend far enough.
    • Four 6mm Phillips screws.
    • Four 3mm Phillips screws.
  8. Upgrading the Lenovo ThinkPad T520 Display, Connector: 步骤 8 中的图像 1,3 Upgrading the Lenovo ThinkPad T520 Display, Connector: 步骤 8 中的图像 2,3 Upgrading the Lenovo ThinkPad T520 Display, Connector: 步骤 8 中的图像 3,3
    • The old LCD is now held on only by the cable. Carefully rotate the display so that it rests on the laptop keyboard.
    • Peel up the tape holding the connector but be careful not to damage the cable.
    • Remove the old display and put it somewhere safe. Someone else might find it useful for repairing a cracked display on a budget. You can use the upgrade screen's shipping package if you sell the display online.
  9. Upgrading the Lenovo ThinkPad T520 Display, In with the new: 步骤 9 中的图像 1,3 Upgrading the Lenovo ThinkPad T520 Display, In with the new: 步骤 9 中的图像 2,3 Upgrading the Lenovo ThinkPad T520 Display, In with the new: 步骤 9 中的图像 3,3
    • Lay the new 1080p LCD on the keyboard and insert the display connector. I found a spuger useful to push on the corners of the connector without damaging the cable.
    • Make sure both round clips are properly secured before taping the connector down. Feel free to add extra tape.
    • Tiny round clips.
  10. Upgrading the Lenovo ThinkPad T520 Display, Put it all back: 步骤 10 中的图像 1,3 Upgrading the Lenovo ThinkPad T520 Display, Put it all back: 步骤 10 中的图像 2,3 Upgrading the Lenovo ThinkPad T520 Display, Put it all back: 步骤 10 中的图像 3,3
    • Rotate the LCD back onto the metal frame, put the battery back in and test it out.
    • If everything looks ok then remove the battery and put the screws in. Remove the protective sheet from the display and put the bezel back on.
  11. Upgrading the Lenovo ThinkPad T520 Display, Calibrate: 步骤 11 中的图像 1,2 Upgrading the Lenovo ThinkPad T520 Display, Calibrate: 步骤 11 中的图像 2,2
    • This display is more capable than the average LCD so if it is adjusted wrong it can be very obvious.
    • Be prepared for a warmer default color temperature than is common on consumer displays. This screen is intended for professional graphics use so it is designed to match colors to how they would look when printed out and viewed under incandescent lighting.
    • Professionals working with graphics use a digital colorimeter to adjust the color accuracy of a display. This process creates what is called an ICC profile that tells programs how to display colors accurately.
    • To simply make the screen look good for viewing images and office use, Windows has a built in Display Color Calibration utility that allows adjustment of the color balance of the display. The Intel IGP software can also be used to make adjustments instead. Right click on the desktop and select Graphics Properties...
    • It is also easy to experiment with color profiles others have created for this display. Every panel will be slightly different but it is possible to find a profile that looks good on your screen. I found that the first ICC profile provided by Sager works for me.
结论
22等其他人完成本指南。
Aaron Zink
于07/13/12注册
861 声望
撰写一个指南
11条评论
Successfully changed screens on a Lenovo T530 from an original 1600x900 to the 1920x1080 make and model mentioned in this guide. I was able to check the difference in quality of the two displays directly running side by side my W520 which has the 1080 and the T530 with the the original screen that I ordered for my father in law. The 1080 is a better screen altogether. And as this guide shows, replacing the screen is really easy - a no-brainer.
Leo S - 回复
Are there fitting differences in the B156HW01 V.4 and the V.5 or V.7? Most places I look the V.4 is out of stock or discontinued.
Benjamin Wilson - 回复
Successfully installed on a Lenovo T520 with an original screen resolution of 1600x900. The new, higher resolution screen was easy to fit, and worked straight away - no need for a new cable or anything like that.
Tom - 回复
Thanks a bunch. Used this guide to replace a full display and hinge from a rather aggressive "drop". Trickiest part is the cable reinsertion - with the sticky tape underneath the original cable install it is a little finicky to get a snug and flat fit.
Best,
-Andrew
Andrew Duszczyszyn - 回复
Very nice guide. One question to be save: wil a upgrade from a standard 1366x768 screen also be possible? I read elsewhere the motherboard or cable wil not support an full HD screen.
Dirk Dirkjes - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 73
总计 47,503
