简介
Upgrade up to 16 GB of RAM memory in your 21.5" iMac
All photos are property of iFixit
你所需要的
First you need to remove the glue from the edge of the iMac
Use a Guitar Pick around the screen to remove the glue
Once you are sure the adhesive is removed, use two heavy suction cups to lift the screen
Unplug these cables:
DisplayPort Cable
Power Cable
Lift the screen from the iMac
Remove these 2 Torx T10 screws
Unplug these 2 cables
Unplug 2 more cable below the power board by pressing the clip
Unscrew 3 Torx T8 screws from the heatsink, then remove the logic board from the iMac
To reassemble your device, follow these instructions in reverse order remembering to re-glue the screen.
11等其他人完成本指南。
