跳转到主内容
Upgrade Storage for the New Nintendo 3DS XL 2015
你所需要的
  1. Upgrade Storage for the New Nintendo 3DS XL 2015, Upgrade Storage: 步骤 1 中的图像 1,1
    • Make sure your device is powered off before advancing to the next step. Failure to do this could result in electrical shock or damage to the device.
    • Power off the device by locating the circular power button and pressing Power Off on the screen.
  2. Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 2 中的图像 1,2 Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 2 中的图像 2,2
    • Turn the Nintendo 3DS around, so that you are looking at the back of the device.
    • Remove the stylus from the device.
    • Failure to remove the stylus can result in damage to the stylus and internal damage to the device.
  3. Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 3 中的图像 1,2 Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 3 中的图像 2,2
    • Remove the game cartridge by pulling it out of its slot.
    • Failure to remove the game cartridge may result in permanent damage to the game.
  4. Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 4 中的图像 1,2 Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 4 中的图像 2,2
    • Loosen the two screws using a Phillips #00 screwdriver.
    • The screws will not completely come out of the backplate. When a clicking sound is heard, the screws will be loose.
  5. Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 5 中的图像 1,3 Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 5 中的图像 2,3 Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 5 中的图像 3,3
    • Wedge the opening pick in the cutout to separate the back plate from the device.
  6. Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 6 中的图像 1,2 Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 6 中的图像 2,2
    • Remove the factory-placed micro SD card from the designated slot by pressing down onto the card.
    • The spring will then pop the card upwards.
    • Slide the card out to fully remove it from the 3DS.
  7. Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 7 中的图像 1,3 Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 7 中的图像 2,3 Upgrade Storage for the New Nintendo 3DS XL 2015: 步骤 7 中的图像 3,3
    • A micro SDHC Memory Card must be used when upgrading the 3DS XL memory from standard 4gb. The maximum upgradable memory is 32gb.
    • Align the new micro SDHC card with the card slot.
    • Verify that the label/ front side of the micro SDHC card is facing towards you when performing these steps.
    • Press downwards on the card until you hear a click. This will verify that the card is properly inserted.
    • After reassembly, check the settings to verify that the storage has been upgraded.
结论
13等其他人完成本指南。
Maysa Rizk
于09/30/19注册
268 声望
撰写一个指南
团队
CSU Fullerton, Team S1-G4, Bruce Fall 2019 CSU Fullerton, Team S1-G4, Bruce Fall 2019 的会员
CSUF-BRUCE-F19S1G4
4 名成员
创作了2篇指南
一条评论
Note that a card larger than 32GB can work, but it needs to be formatted externally into FAT32, and it will slow down boot time of the console startup and game startup slightly too.
mjesticfalco - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 88
过去 30 天: 371
总计 19,526
