跳转到主内容
Untracked Bifold Door Pin Replacement
你所需要的
  1. Untracked Bifold Door Pin Replacement, Bifold Door Pin: 步骤 1 中的图像 1,1
    • Stand on a small ladder or step stool to get a better view of the top of the door.
  2. Untracked Bifold Door Pin Replacement: 步骤 2 中的图像 1,1
    • Locate the pin at the top of the door.
  3. Untracked Bifold Door Pin Replacement: 步骤 3 中的图像 1,1
    • Remove the current pin with pliers.
  4. Untracked Bifold Door Pin Replacement: 步骤 4 中的图像 1,2 Untracked Bifold Door Pin Replacement: 步骤 4 中的图像 2,2
    • Clean the top of the door using cleaning spray and a rag. This will help remove any dust or wood fragments left behind.
    • I used Meyer's spray, but any household cleaning spray will work just fine.
  5. Untracked Bifold Door Pin Replacement: 步骤 5 中的图像 1,1
    • Replace old pin with new pin using the pliers to place into the hole at the top of the door.
    • You can purchase a new pin at either Ace Hardware or Home Depot.
  6. Untracked Bifold Door Pin Replacement: 步骤 6 中的图像 1,1
    • Push the pin all the way in by using a hammer.
    • No excessive force is needed. Gently tap the pin with the hammer until it is secured.
  7. Untracked Bifold Door Pin Replacement: 步骤 7 中的图像 1,1
    • Line up the newly placed pin with the door's tracking.
    • Push the door down slightly and then lift it back up to align it with the track.
  8. Untracked Bifold Door Pin Replacement: 步骤 8 中的图像 1,1
    • Secure the pin within the tracking using the pliers.
  9. Untracked Bifold Door Pin Replacement: 步骤 9 中的图像 1,1
    • When completed, the bifold doors should close and be positioned within the tracking.
结论
Catelyn Carpenter
于01/16/20注册
169 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 53
总计 1,389
