跳转到主内容
Unsticking SteelSeries Nimbus Triggers
你所需要的
  1. Unsticking SteelSeries Nimbus Triggers, Unsticking SteelSeries Nimbus Triggers: 步骤 1 中的图像 1,1
    • When your triggers get stickier than the Cheeto® dust on your hands it might be time for an intervention.
  2. Unsticking SteelSeries Nimbus Triggers: 步骤 2 中的图像 1,2 Unsticking SteelSeries Nimbus Triggers: 步骤 2 中的图像 2,2
    • Start off by removing the four TR9 Torx Security screws on the back of the controller.
  3. Unsticking SteelSeries Nimbus Triggers: 步骤 3 中的图像 1,3 Unsticking SteelSeries Nimbus Triggers: 步骤 3 中的图像 2,3 Unsticking SteelSeries Nimbus Triggers: 步骤 3 中的图像 3,3
    • The two screws on the top are further inset than the others. You can use the iFixit 1/4" to 4 mm Driver Adapter as an extender.
  4. Unsticking SteelSeries Nimbus Triggers: 步骤 4 中的图像 1,2 Unsticking SteelSeries Nimbus Triggers: 步骤 4 中的图像 2,2
    • The case is now open, but it's still held together by two clips on the top.
  5. Unsticking SteelSeries Nimbus Triggers: 步骤 5 中的图像 1,3 Unsticking SteelSeries Nimbus Triggers: 步骤 5 中的图像 2,3 Unsticking SteelSeries Nimbus Triggers: 步骤 5 中的图像 3,3
    • Apply a gentle twisting motion to separate the first clip.
    • Twist in the other direction to separate the second clip.
    • The top is now free!
  6. Unsticking SteelSeries Nimbus Triggers: 步骤 6 中的图像 1,3 Unsticking SteelSeries Nimbus Triggers: 步骤 6 中的图像 2,3 Unsticking SteelSeries Nimbus Triggers: 步骤 6 中的图像 3,3
    • Be mindful of the three cables still connecting the two halves.
  7. Unsticking SteelSeries Nimbus Triggers: 步骤 7 中的图像 1,2 Unsticking SteelSeries Nimbus Triggers: 步骤 7 中的图像 2,2
    • Here's our problem, the rubber pad has fallen off of the plastic stop leaving only the glue behind.
    • The rubber pad should still be in the controller somewhere (happy hunting) or if you're not in the mood for hide and seek any kind of foam will work as a replacement.
结论
8等其他人完成本指南。
Jonathan
于03/13/13注册
464 声望
创作了2篇指南
4条评论
Great, concise fix instructions!
Brian Pippen - 回复
My nimbus started to have sticky triggers. I could not believe that I had found this solution! Awesome!
Max-Heinrich Laves - 回复
Hi, I have a Nimbus + controller. It's seems to have clips at the back too. Any advice on how to open it?
Sean Hudson - 回复
Greetings, someone who can help me where I can get the joystick, original remote control ?
Excellent information
bryan Andino - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 12
过去 30 天: 57
总计 6,263
