跳转到主内容
Unnecto Drone M Headphone Jack Replacement
你所需要的
  1. Unnecto Drone M Headphone Jack Replacement, Unnecto Drone M Disassembly: 步骤 1 中的图像 1,2 Unnecto Drone M Headphone Jack Replacement, Unnecto Drone M Disassembly: 步骤 1 中的图像 2,2
    • Place the phone facedown on a cleared work area
    • Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
  2. Unnecto Drone M Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Grip the top right corner of the battery.
    • Remove the battery by pulling it outwards.
  3. Unnecto Drone M Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Remove the four screws on the back of the phone using a Philips 000 screwdriver
  4. Unnecto Drone M Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Separate the frame evenly using a plastic opening tool.
    • Be careful, as the frame is thin and can break easily.
  5. Unnecto Drone M Headphone Jack Replacement: 步骤 5 中的图像 1,2 Unnecto Drone M Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
  6. Unnecto Drone M Headphone Jack Replacement: 步骤 6 中的图像 1,1
    • Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
  7. Unnecto Drone M Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
    • The white circuit is flimsy and securely glued to the frame.
  8. Unnecto Drone M Headphone Jack Replacement: 步骤 8 中的图像 1,2 Unnecto Drone M Headphone Jack Replacement: 步骤 8 中的图像 2,2
    • Set aside the circuit board from the screen protector.
  9. Unnecto Drone M Headphone Jack Replacement, Headphone Jack: 步骤 9 中的图像 1,3 Unnecto Drone M Headphone Jack Replacement, Headphone Jack: 步骤 9 中的图像 2,3 Unnecto Drone M Headphone Jack Replacement, Headphone Jack: 步骤 9 中的图像 3,3
    • Desolder the headphone jack using a soldering iron on each of the 6 points holding it down.
    • Be careful to not damage the circuit board.
  10. Unnecto Drone M Headphone Jack Replacement: 步骤 10 中的图像 1,2 Unnecto Drone M Headphone Jack Replacement: 步骤 10 中的图像 2,2
    • Solder on a new headphone jack.
  11. Unnecto Drone M Headphone Jack Replacement: 步骤 11 中的图像 1,1
    • Make sure the new jack is aligned properly and securely soldered to the circuit board.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 170
