跳转到主内容
Unihut Titan Pocket Keyboard Disassembly Guide
你所需要的
  1. Unihut Titan Pocket Keyboard Disassembly Guide, Side plates disassembly: 步骤 1 中的图像 1,3 Unihut Titan Pocket Keyboard Disassembly Guide, Side plates disassembly: 步骤 1 中的图像 2,3 Unihut Titan Pocket Keyboard Disassembly Guide, Side plates disassembly: 步骤 1 中的图像 3,3
    • Use a Torx T5 screwdriver to remove the 3 screws.
    • Remove the Sim tray.
  2. Unihut Titan Pocket Keyboard Disassembly Guide, Back plate screws: 步骤 2 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the 4 screws.
  3. Unihut Titan Pocket Keyboard Disassembly Guide, Back plate disassembly: 步骤 3 中的图像 1,3 Unihut Titan Pocket Keyboard Disassembly Guide, Back plate disassembly: 步骤 3 中的图像 2,3 Unihut Titan Pocket Keyboard Disassembly Guide, Back plate disassembly: 步骤 3 中的图像 3,3
    • Insert the opening pick into the gap between the body and the back plate. Then open the gap so that the latch comes out.
    • There are three latches on the left and right, one on the top and two on the bottom.
  4. Unihut Titan Pocket Keyboard Disassembly Guide, Bottom part disassembly: 步骤 4 中的图像 1,3 Unihut Titan Pocket Keyboard Disassembly Guide, Bottom part disassembly: 步骤 4 中的图像 2,3 Unihut Titan Pocket Keyboard Disassembly Guide, Bottom part disassembly: 步骤 4 中的图像 3,3
    • Remove the 3 screws using a Phillips #000 screwdriver.
    • Use the opening tool to open the gap.
  5. Unihut Titan Pocket Keyboard Disassembly Guide, Battery disassembly: 步骤 5 中的图像 1,3 Unihut Titan Pocket Keyboard Disassembly Guide, Battery disassembly: 步骤 5 中的图像 2,3 Unihut Titan Pocket Keyboard Disassembly Guide, Battery disassembly: 步骤 5 中的图像 3,3
    • Remove the battery connector.
    • Do not remove including a black sponge. Only disconnect the silver connector.
    • Then, lift the battery.
  6. Unihut Titan Pocket Keyboard Disassembly Guide, Upper part disassembly: 步骤 6 中的图像 1,3 Unihut Titan Pocket Keyboard Disassembly Guide, Upper part disassembly: 步骤 6 中的图像 2,3 Unihut Titan Pocket Keyboard Disassembly Guide, Upper part disassembly: 步骤 6 中的图像 3,3
    • Remove the 2 screws using a Phillips #000 screwdriver.
    • Lift the top part with the pointed part of the Spudger.
    • You don't have to remove the metal sticker by just lifting the top part.
    • If the camera or earphone jack connector is disconnected during the lifting process, reconnect it.
  7. Unihut Titan Pocket Keyboard Disassembly Guide, Motherboard disassembly: 步骤 7 中的图像 1,3 Unihut Titan Pocket Keyboard Disassembly Guide, Motherboard disassembly: 步骤 7 中的图像 2,3 Unihut Titan Pocket Keyboard Disassembly Guide, Motherboard disassembly: 步骤 7 中的图像 3,3
    • Disconnect the 6 connectors.
    • Remove the 5 screws using a Phillips #000 screwdriver.
    • Use the Spudger to lift the top of the motherboard.
  8. Unihut Titan Pocket Keyboard Disassembly Guide, Keyboard disassembly: 步骤 8 中的图像 1,3 Unihut Titan Pocket Keyboard Disassembly Guide, Keyboard disassembly: 步骤 8 中的图像 2,3 Unihut Titan Pocket Keyboard Disassembly Guide, Keyboard disassembly: 步骤 8 中的图像 3,3
    • Insert a thin thing such as a Sim pin through the hole where the screw was removed and push the keyboard out.
  9. Unihut Titan Pocket Keyboard Disassembly Guide, Keyboard disassembly: 步骤 9 中的图像 1,1
    • Remove the 17 plastic rivets to separate the board and keyboard.
    • Since plastic rivets cannot be reused after they are initially removed, they must be reassembled using tools such as glue.
结论
To reassemble the device, follow the instructions in reverse order.
2等其他人完成本指南。
由衷感谢以下译者:
ko en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
glwps
于08/02/20注册
301 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 48
过去 30 天: 243
总计 4,455
