跳转到主内容
加入维修社区 - 创建账户
Uniden UTAB71 Screen Replacement
你所需要的
  1. Uniden UTAB71 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Uniden UTAB71 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Use a pry tool to undo the clips that attach the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Screen Replacement: 步骤 2 中的图像 1,2 Uniden UTAB71 Screen Replacement: 步骤 2 中的图像 2,2
    • Lift off the black clip connecting the first power ribbon to the motherboard
    • Undo the clips off the second power ribbon connecting the screen to the motherboard.
  3. Uniden UTAB71 Screen Replacement: 步骤 3 中的图像 1,3 Uniden UTAB71 Screen Replacement: 步骤 3 中的图像 2,3 Uniden UTAB71 Screen Replacement: 步骤 3 中的图像 3,3
    • Slowly remove the screen component off the tablet by clipping the screen from the tablet outine
    • Do not apply too much pressure on the tablet casing.
结论
另外一个人完成了本指南。
Ryan Jewell
于10/20/16注册
431 声望
创作了4篇指南
团队
UMass Dartmouth, Team 5-4, Martin Fall 2016 UMass Dartmouth, Team 5-4, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G4
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 467
