跳转到主内容
加入维修社区 - 创建账户
Uniden TCX905 Button Keypad Cleaning Guide
你所需要的
  1. Uniden TCX905 Button Keypad Cleaning Guide, Battery Cover: 步骤 1 中的图像 1,2 Uniden TCX905 Button Keypad Cleaning Guide, Battery Cover: 步骤 1 中的图像 2,2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
    询问修复机器人
    添加评论
  2. Uniden TCX905 Button Keypad Cleaning Guide, Battery Pack: 步骤 2 中的图像 1,2 Uniden TCX905 Button Keypad Cleaning Guide, Battery Pack: 步骤 2 中的图像 2,2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
    询问修复机器人
    添加评论
  3. Uniden TCX905 Button Keypad Cleaning Guide, Back Shell: 步骤 3 中的图像 1,2 Uniden TCX905 Button Keypad Cleaning Guide, Back Shell: 步骤 3 中的图像 2,2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
    询问修复机器人
    添加评论
  4. Uniden TCX905 Button Keypad Cleaning Guide: 步骤 4 中的图像 1,3 Uniden TCX905 Button Keypad Cleaning Guide: 步骤 4 中的图像 2,3 Uniden TCX905 Button Keypad Cleaning Guide: 步骤 4 中的图像 3,3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
    询问修复机器人
    添加评论
  5. Uniden TCX905 Button Keypad Cleaning Guide: 步骤 5 中的图像 1,3 Uniden TCX905 Button Keypad Cleaning Guide: 步骤 5 中的图像 2,3 Uniden TCX905 Button Keypad Cleaning Guide: 步骤 5 中的图像 3,3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
    询问修复机器人
    添加评论
  6. Uniden TCX905 Button Keypad Cleaning Guide, Circuit Board: 步骤 6 中的图像 1,2 Uniden TCX905 Button Keypad Cleaning Guide, Circuit Board: 步骤 6 中的图像 2,2
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
    询问修复机器人
    添加评论
  7. Uniden TCX905 Button Keypad Cleaning Guide: 步骤 7 中的图像 1,3 Uniden TCX905 Button Keypad Cleaning Guide: 步骤 7 中的图像 2,3 Uniden TCX905 Button Keypad Cleaning Guide: 步骤 7 中的图像 3,3
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
    询问修复机器人
    添加评论
  8. Uniden TCX905 Button Keypad Cleaning Guide, Button Keypad: 步骤 8 中的图像 1,3 Uniden TCX905 Button Keypad Cleaning Guide, Button Keypad: 步骤 8 中的图像 2,3 Uniden TCX905 Button Keypad Cleaning Guide, Button Keypad: 步骤 8 中的图像 3,3
    • Remove the white plastic sheet covering the button pad with your fingers
    • Gently remove the silicon button pad
    询问修复机器人
    添加评论
  9. Uniden TCX905 Button Keypad Cleaning Guide: 步骤 9 中的图像 1,2 Uniden TCX905 Button Keypad Cleaning Guide: 步骤 9 中的图像 2,2
    • Wet one end of the cotton swab with water and clean button pad as needed
    • Repeat process with multiple cotton swabs if needed
    • Dry the button pad with a clean, soft rag before replacing
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Gary Pence
于03/26/14注册
807 声望
创作了8篇指南
团队
Clemson, Team 1-1, Benson Spring 2014 Clemson, Team 1-1, Benson Spring 2014 的会员
CLEM-BENSON-S14S1G1
3 名成员
创作了32篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 1,263
