当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Starting from the top of the cover, slide down and away from the phone with your thumb
Lift battery cover off of batter and place it to the side
Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
Place battery pack to the side
Lay the back shell with the inside facing up
To remove the speaker guard, first remove the 7mm screw from inside the back shell
To access the speaker, flip the back shell over and use a plastic opening tool to pop open the black cover
Gently push the speaker guard out of place with your thumb
Carefully slide the speaker out from its setting and place speaker guard aside
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
