跳转到主内容
Uniden Guardian G955 Speaker Replacement
你所需要的
  1. Uniden Guardian G955 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Using a J1 Philips head screwdriver, unscrew all four 6.1 mm screws.
  2. Uniden Guardian G955 Speaker Replacement: 步骤 2 中的图像 1,1
    • Using a metal spudger, open the monitor from the corner. Slowly slide the spudger around the case to prop open the case.
  3. Uniden Guardian G955 Speaker Replacement: 步骤 3 中的图像 1,2 Uniden Guardian G955 Speaker Replacement: 步骤 3 中的图像 2,2
    • Locate the circular speaker in one of the corners of the device. To release the speaker, pinch the metal fastener together and lift it off of the speaker.
  4. Uniden Guardian G955 Speaker Replacement: 步骤 4 中的图像 1,2 Uniden Guardian G955 Speaker Replacement: 步骤 4 中的图像 2,2
    • Follow the speaker towards the input on the motherboard. Pull it from the motherboard horizontally for it to loosen easier.
    • You may have to wiggle the head of the wire to efficiently remove it from the motherboard.
  5. Uniden Guardian G955 Speaker Replacement: 步骤 5 中的图像 1,2 Uniden Guardian G955 Speaker Replacement: 步骤 5 中的图像 2,2
    • Using an angled ESD tweezer, pull back on the black clamp with one hand while lifting the wires with the other hand.
    • You will have to apply a large amount of force on the black clamp to get it to move enough to lift the two wires out of it.
  6. Uniden Guardian G955 Speaker Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the speaker and all of the components in the speaker socket off of the monitor.
    • The speaker's film may be glued down to the socket where it's held. If this is the case, you must pull it all off and carefully clean it so that you may add the new speaker and ensure it fits with no leftover glue residue from the previous speaker.
结论
Fabian Demiro
于10/06/16注册
177 声望
撰写一个指南
团队
USF Tampa, Team 1-1, Nance Fall 2016 USF Tampa, Team 1-1, Nance Fall 2016 的会员
USFT-NANCE-F16S1G1
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 260
