跳转到主内容
Uniden Guardian G955 Battery Replacement
你所需要的
  1. Uniden Guardian G955 Battery  Replacement, Battery: 步骤 1 中的图像 1,1
    • First, remove four 6.1 mm screws from your monitor using a J1 Phillips head screwdriver.
  2. Uniden Guardian G955 Battery  Replacement: 步骤 2 中的图像 1,1
    • Carefully, use a metal spudger to open the case starting from any corner.
    • Slowly slide the spudger along the inside edge of the case.
  3. Uniden Guardian G955 Battery  Replacement: 步骤 3 中的图像 1,2 Uniden Guardian G955 Battery  Replacement: 步骤 3 中的图像 2,2
    • Remove the two 6.1 mm screws from the black fastener using a screwdriver.
    • Remove the black fastener.
  4. Uniden Guardian G955 Battery  Replacement: 步骤 4 中的图像 1,2 Uniden Guardian G955 Battery  Replacement: 步骤 4 中的图像 2,2
    • Disconnect the head of the cable attached to the motherboard by pressing on the outer edge of the cable and sliding it out.
  5. Uniden Guardian G955 Battery  Replacement: 步骤 5 中的图像 1,2 Uniden Guardian G955 Battery  Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    • Remove the battery from the case by sliding a halberd spudger below it. (note: the spudger shown is metal, to ensure proper safety, utilize a nylon or plastic spudger.)
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 1-1, Nance Fall 2016 USF Tampa, Team 1-1, Nance Fall 2016 的会员
USFT-NANCE-F16S1G1
3 名成员
创作了8篇指南
4指南评论
The instructions and illustrations are fine, but there is NO information on how to obtain a replacement battery. I have searched without any luck.
Ricaedo Garcia - 回复
Hello, I sure hope I can get a answer on this, Ricaedo Garcia was you able to find a replacement battery for yours. I been searching for one and no luck. Thank you
Kathy -
I’m going to try using this battery: YK843553-Battery-for-UNIDEN-UBW2101C-Camera-UBWC21-1250mAh
I think it will work. The connector and voltage are the same.
George Scott - 回复
George Scott: Did that battery work satisfactorily?
PhBob - - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 33
总计 6,166
