跳转到主内容
加入维修社区 - 创建账户
Uniden EXP 371 Keypad Replacement
你所需要的
  1. Uniden EXP 371 Keypad Replacement, Dissassemble the Uniden EXP 371 phone: 步骤 1 中的图像 1,1
    • Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
  2. Uniden EXP 371 Keypad Replacement: 步骤 2 中的图像 1,3 Uniden EXP 371 Keypad Replacement: 步骤 2 中的图像 2,3 Uniden EXP 371 Keypad Replacement: 步骤 2 中的图像 3,3
    • Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
  3. Uniden EXP 371 Keypad Replacement: 步骤 3 中的图像 1,2 Uniden EXP 371 Keypad Replacement: 步骤 3 中的图像 2,2
    • Remove the motherboard once the screws holding it in place are undone.
    • Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
  4. Uniden EXP 371 Keypad Replacement: 步骤 4 中的图像 1,1
    • After the rubber pad is removed remove the dial pad (buttons) from the phone.
  5. Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: 步骤 5 中的图像 1,2 Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: 步骤 5 中的图像 2,2
    • If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons.
    • Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
  6. Uniden EXP 371 Keypad Replacement, Order a New Dial Pad: 步骤 6 中的图像 1,1
结论
Lucas Mohsen
于10/31/14注册
101 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-1, Duarte Fall 2014 UMass Dartmouth, Team 2-1, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 235
