跳转到主内容
Uniden EXP 371 Handset Casing Replacement
你所需要的
  1. Uniden EXP 371 Handset Casing Replacement, Uniden EXP 371 Teardown: 步骤 1 中的图像 1,1
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Handset Casing Replacement: 步骤 2 中的图像 1,2 Uniden EXP 371 Handset Casing Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Handset Casing Replacement: 步骤 3 中的图像 1,2 Uniden EXP 371 Handset Casing Replacement: 步骤 3 中的图像 2,2
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Handset Casing Replacement: 步骤 4 中的图像 1,3 Uniden EXP 371 Handset Casing Replacement: 步骤 4 中的图像 2,3 Uniden EXP 371 Handset Casing Replacement: 步骤 4 中的图像 3,3
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
  5. Uniden EXP 371 Handset Casing Replacement, Handset Casing: 步骤 5 中的图像 1,1
    • You must remove the speakers in order to replace the front casing of the phone. Use the #1 philips screwdriver.
    • Once the phone is completely disassembled follow the steps in the reverse order using the new phone case to reassemble your phone.
结论
Ethan DiTullio
于10/17/14注册
125 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-1, Duarte Fall 2014 UMass Dartmouth, Team 2-1, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 128
