跳转到主内容
Uniden EXP 371 Charging Contact Points Replacement
你所需要的
  1. Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: 步骤 1 中的图像 1,2 Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: 步骤 1 中的图像 2,2
    • Your first step will be to remove the battery cover and the battery.
  2. Uniden EXP 371 Charging Contact Points Replacement: 步骤 2 中的图像 1,1
    • The next step will be to remove the two screws from the rear of the phone case.
  3. Uniden EXP 371 Charging Contact Points Replacement: 步骤 3 中的图像 1,1
    • After that you will need to pry the back of the case off of the front part of the case.
  4. Uniden EXP 371 Charging Contact Points Replacement: 步骤 4 中的图像 1,2 Uniden EXP 371 Charging Contact Points Replacement: 步骤 4 中的图像 2,2
    • After removing the rear cover there will be two more screws to remove that hold each of the charging contact points. Once those are removed you can replace them with the new ones.
    • When replacing the charging contacts, they only go on one way, but it is useful to note how the original ones were on.
    • Reverse these steps in order to reassemble your phone.
结论
Eric Rodrigues
于10/16/14注册
343 声望
创作了3篇指南
团队
UMass Dartmouth, Team 2-1, Duarte Fall 2014 UMass Dartmouth, Team 2-1, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 166
