跳转到主内容
Uniden EXP 371 Battery Replacement
  1. Uniden EXP 371 Battery Replacement, Battery Cover: 步骤 1 中的图像 1,1
    • To remove the battery cover, push in and downwards towards yourself on the cover. There is a notch on the back that you can use to get a better grip if necessary.
  2. Uniden EXP 371 Battery Replacement: 步骤 2 中的图像 1,1
    • Pull the battery away from the battery housing. At the end of the wires on the housing side there is a clip that connects the battery to the phone. Unplug this clip and discard the warn battery appropriately.
  3. Uniden EXP 371 Battery Replacement: 步骤 3 中的图像 1,1
    • Now take your new battery pack and insert the new plug into the housing. The plug should smoothly clip right into the phone.
    • If the clip does not fit easily into the housing, compare the new battery with the old and be sure they are the same.
  4. Uniden EXP 371 Battery Replacement, Replace Battery: 步骤 4 中的图像 1,1
    • Push the wires back into the housing to allow the battery to fit under the battery cover.
    • Put the cover back on. Listen for a click, which will indicate the cover is placed correctly.
结论
Eric Rodrigues
于10/16/14注册
343 声望
创作了3篇指南
团队
UMass Dartmouth, Team 2-1, Duarte Fall 2014 UMass Dartmouth, Team 2-1, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 12
总计 166
