跳转到主内容
Uniden Dect 6.0 Keyboard Replacement
你所需要的
  1. Uniden Dect 6.0 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 Uniden Dect 6.0 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
结论
另外一个人完成了本指南。
Megan Lawrence
于01/14/15注册
534 声望
创作了5篇指南
团队
一条评论
Great to have this guide! I’d add that (at least on my aging handset). Prying it open can feel a bit sketchy cause it may resist a bit, so I used the metal spudger to go around the edge lifting the tabs. But the plastic on these is pretty great and will not break even puting some force on it.
Also be mindful of the speaker on the back which is connected to the front case.
Ivan Viales - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 3,405
