跳转到主内容
加入维修社区 - 创建账户
Uniden Dect 6.0 Display Replacement
你所需要的
  1. Uniden Dect 6.0 Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Display Replacement: 步骤 2 中的图像 1,1
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Display Replacement: 步骤 3 中的图像 1,1
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Display Replacement, Keyboard: 步骤 4 中的图像 1,2 Uniden Dect 6.0 Display Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Display Replacement: 步骤 5 中的图像 1,1
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Display Replacement: 步骤 6 中的图像 1,1
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
  7. Uniden Dect 6.0 Display Replacement, Gel Casing: 步骤 7 中的图像 1,1
    • To better access the screen, remove the loose gel casing that sits under the keyboard.
  8. Uniden Dect 6.0 Display Replacement: 步骤 8 中的图像 1,1
    • Lift out the attached motherboard piece and turn it sideways to access the side of the phone.
    • Potential for device damage: Use caution to avoid severing the wires that connect the motherboard to the phone.
  9. Uniden Dect 6.0 Display Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    • Gently use the tweezers to access the motherboard panel and lift it straight up.
结论
3等其他人完成本指南。
Megan Lawrence
于01/14/15注册
534 声望
创作了5篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 46
总计 6,952
