跳转到主内容
Uniden D1688 multistation and handset disassembly
你所需要的
  1. Uniden D1688 multistation and handset disassembly, Uniden D1688 multistation and handset disassembly: 步骤 1 中的图像 1,1
    • Unplug the phone from the base by detaching the RJ-11 plug.
    • Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
  2. Uniden D1688 multistation and handset disassembly: 步骤 2 中的图像 1,1
    • Using the spudger, separate the top shell of the base from the bottom shell from the base.
    • Use care when separating the base so the ribbon cable between the top shell circuit board and the bottom shell circuit board is not damaged!
  3. Uniden D1688 multistation and handset disassembly: 步骤 3 中的图像 1,1
    • Unscrew the 3 screws (Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
  4. Uniden D1688 multistation and handset disassembly: 步骤 4 中的图像 1,1
    • Unscrew the 2 screws (Head Size: 4mm Length: 8.66) on the small circuit board in the top shell.
  5. Uniden D1688 multistation and handset disassembly: 步骤 5 中的图像 1,1
    • Disconnect the ribbon cable from the bottom shell circuit board.
  6. Uniden D1688 multistation and handset disassembly: 步骤 6 中的图像 1,1
    • Release the speaker from the locking pin by pushing down on each ending side of the pin and pushing it away from the speaker.
  7. Uniden D1688 multistation and handset disassembly: 步骤 7 中的图像 1,1
    • Remove rubber keyboard underlay from top shell.
  8. Uniden D1688 multistation and handset disassembly: 步骤 8 中的图像 1,1
    • Push the plastic keyboard pieces out of the top shell.
  9. Uniden D1688 multistation and handset disassembly: 步骤 9 中的图像 1,1
    • Unscrew bottom shell circuit board screws (Head size: 4mm Length: 8.6mm).
  10. Uniden D1688 multistation and handset disassembly: 步骤 10 中的图像 1,1
    • The disassembly of the phone base is complete!
    • Now this guide will move on to taking apart one of the handsets.
  11. Uniden D1688 multistation and handset disassembly: 步骤 11 中的图像 1,1
    • Slide the battery cover off of the handset, and unplug the battery.
  12. Uniden D1688 multistation and handset disassembly: 步骤 12 中的图像 1,1
    • Remove the battery, and unscrew the two screws (Head Size: 4mm Length: 8.6 mm).
  13. Uniden D1688 multistation and handset disassembly: 步骤 13 中的图像 1,1
    • Use spudger to separate the phone shell.
  14. Uniden D1688 multistation and handset disassembly: 步骤 14 中的图像 1,1
    • Unscrew the two screws (Head Size: 4mm Length: 8.6mm) on the bottom shell keeping the speaker locking pin in place.
结论
Nicholas Weeks
于01/27/15注册
101 声望
撰写一个指南
团队
Pasco Hernando, Team 1-4, Prince Winter 2015 Pasco Hernando, Team 1-4, Prince Winter 2015 的会员
PHSC-PRINCE-W15S1G4
6 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 539
