跳转到主内容
Uniden D1688 Top Circuit Board Replacement
你所需要的
  1. Uniden D1688 Top Circuit Board Replacement, Uniden D1688 Base Replacement: 步骤 1 中的图像 1,1
    • Unplug the phone from the base by detaching the RJ-11 plug.
    • Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
  2. Uniden D1688 Top Circuit Board Replacement: 步骤 2 中的图像 1,2 Uniden D1688 Top Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Using the spudger, separate the top shell of the base from the bottom shell from the base.
    • Use care when separating the base so the ribbon cable between the top shell circuit board and the bottom shell circuit board is not damaged!
    • Lift the top shell off the bottom, and you have successfully opened the phone base.
  3. Uniden D1688 Top Circuit Board Replacement, Top Circuit Board: 步骤 3 中的图像 1,1
    • Unscrew the 3 screws(Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
  4. Uniden D1688 Top Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Unscrew the 2 screws (Head Size: 4mm Length: 8.66) on the small circuit board in the top shell.
  5. Uniden D1688 Top Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Disconnect the ribbon cable from the bottom shell circuit board.
  6. Uniden D1688 Top Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Release the speaker from the locking pin by pushing down on each ending side of the pin and pushing it away from the speaker.
  7. Uniden D1688 Top Circuit Board Replacement: 步骤 7 中的图像 1,1
    • Remove top shell circuit board by lifting the circuit board out of the case
结论
justin
于01/26/15注册
419 声望
创作了4篇指南
团队
Pasco Hernando, Team 1-4, Prince Winter 2015 Pasco Hernando, Team 1-4, Prince Winter 2015 的会员
PHSC-PRINCE-W15S1G4
6 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 185
