简介
We are going to teach you how to remove bottom shell circuit board. By removing this, you will learn how to dissemble the speaker.
你所需要的
Unplug the phone from the base by detaching the RJ-11 plug.
Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
Unscrew the 3 screws(Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
Unscrew bottom shell circuit board screws(Head size: 4mm Length: 8.6mm).
即将完成!
结论
