跳转到主内容
Uniden D1688 Base Replacement
你所需要的
  1. Uniden D1688 Base Replacement, Uniden D1688 Base Replacement: 步骤 1 中的图像 1,1
    • Unplug the phone from the base by detaching the RJ-11 plug.
    • Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
  2. Uniden D1688 Base Replacement: 步骤 2 中的图像 1,2 Uniden D1688 Base Replacement: 步骤 2 中的图像 2,2
    • Using the spudger, separate the top shell of the base from the bottom shell from the base.
    • Use care when separating the base so the ribbon cable between the top shell circuit board and the bottom shell circuit board is not damaged!
    • Lift the top shell off the bottom, and you have successfully opened the phone base.
结论
另外一个人完成了本指南。
justin
于01/26/15注册
419 声望
创作了4篇指南
团队
Pasco Hernando, Team 1-4, Prince Winter 2015 Pasco Hernando, Team 1-4, Prince Winter 2015 的会员
PHSC-PRINCE-W15S1G4
6 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 276
