跳转到主内容
Uniden D1483-3BK Circuit Board/Screen Replacement
你所需要的
  1. Uniden D1483-3BK Circuit Board/Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 2 中的图像 1,2 Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 2 中的图像 2,2
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: 步骤 4 中的图像 1,2 Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: 步骤 4 中的图像 2,2
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 5 中的图像 1,3 Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 5 中的图像 2,3 Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 6 中的图像 1,2 Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 7 中的图像 1,2 Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 7 中的图像 2,2
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Circuit Board/Screen Replacement, Circuit Board/Screen: 步骤 8 中的图像 1,1
    • Set the circuit board on the table with the screen facing down.
  9. Uniden D1483-3BK Circuit Board/Screen Replacement: 步骤 9 中的图像 1,1
    • Using the desoldering braid and soldering iron, remove the solder around the cable for the speaker.
    • When installing the new board, use the soldering iron and solder to reattach the speaker cables.
结论
6等其他人完成本指南。
Arbitrary Name
于01/28/15注册
1,083 声望
创作了4篇指南
团队
Penn State, Team 1-8, Kaschak Winter 2015 Penn State, Team 1-8, Kaschak Winter 2015 的会员
PSU-KASCHAK-W15S1G8
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 395
