跳转到主内容
Unbranded UB-15MS10 Screen Replacement
你所需要的
  1. Unbranded UB-15MS10 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Use an opening tool to pry off the lid of the memory card compartment.
  2. Unbranded UB-15MS10 Screen Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 Screwdriver to unscrew the two 1.2mm screws within the compartment. This allows the device to be opened.
  3. Unbranded UB-15MS10 Screen Replacement: 步骤 3 中的图像 1,2 Unbranded UB-15MS10 Screen Replacement: 步骤 3 中的图像 2,2
    • Insert opening tools to partially pry open the cover.
  4. Unbranded UB-15MS10 Screen Replacement: 步骤 4 中的图像 1,1
    • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
  5. Unbranded UB-15MS10 Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the tape that is holding the battery in place.
  6. Unbranded UB-15MS10 Screen Replacement: 步骤 6 中的图像 1,1
    • Unscrew the five 1.2mm screws that connect the circuit board to the device.
  7. Unbranded UB-15MS10 Screen Replacement: 步骤 7 中的图像 1,1
    • There are three silver tabs around the internal components that connect it to the frame with screws. Unscrew these screws to remove the internal components.
  8. Unbranded UB-15MS10 Screen Replacement: 步骤 8 中的图像 1,1
    • Carefully lift the internal components from the screen and place them into a replacement screen.
结论
To reassemble your device, follow instructions 1-7 in reverse order.
2等其他人完成本指南。
Evan Peterson
于03/08/17注册
320 声望
创作了2篇指南
团队
一条评论
All the instruction are fine to follow except the last one, step 8. What tool to use to lift the internal components from the screen frame or where to start to lift without damage to the internal components?
Alfred H. Schaefer - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 11
总计 1,903
