跳转到主内容
Unbranded UB-15MS10 Power Button Replacement
你所需要的
  1. Unbranded UB-15MS10 Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 Unbranded UB-15MS10 Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 Unbranded UB-15MS10 Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Use an opening tool to pry off the memory card door located on the back of the tablet.
  2. Unbranded UB-15MS10 Power Button Replacement: 步骤 2 中的图像 1,1
    • Remove the two 1.2mm screws found under the memory card door.
  3. Unbranded UB-15MS10 Power Button Replacement: 步骤 3 中的图像 1,3 Unbranded UB-15MS10 Power Button Replacement: 步骤 3 中的图像 2,3 Unbranded UB-15MS10 Power Button Replacement: 步骤 3 中的图像 3,3
    • Pry around the outside carefully using the black spudger to get in. Putting many opening tools around the edge helps keep it from sealing shut again.
  4. Unbranded UB-15MS10 Power Button Replacement: 步骤 4 中的图像 1,2 Unbranded UB-15MS10 Power Button Replacement: 步骤 4 中的图像 2,2
    • Remove the ribbon cable by using the black spudger to release the tab and carefully pull out the ribbon cable.
  5. Unbranded UB-15MS10 Power Button Replacement: 步骤 5 中的图像 1,3 Unbranded UB-15MS10 Power Button Replacement: 步骤 5 中的图像 2,3 Unbranded UB-15MS10 Power Button Replacement: 步骤 5 中的图像 3,3
    • Peel up the grey tape so that you can get to the board and untape the ribbon cable that was removed from the motherboard in the previous step.
  6. Unbranded UB-15MS10 Power Button Replacement: 步骤 6 中的图像 1,2 Unbranded UB-15MS10 Power Button Replacement: 步骤 6 中的图像 2,2
    • Remove the two 1.2mm screws from the board.
  7. Unbranded UB-15MS10 Power Button Replacement: 步骤 7 中的图像 1,1
    • Use an opening tool to remove the board from the case.
  8. Unbranded UB-15MS10 Power Button Replacement: 步骤 8 中的图像 1,2 Unbranded UB-15MS10 Power Button Replacement: 步骤 8 中的图像 2,2
    • Detach the three ribbon cables using spudger in the first picture. Then cut the black, white, and red wires shown in picture two.
  9. Unbranded UB-15MS10 Power Button Replacement: 步骤 9 中的图像 1,1
    • Check to see if plastic power button is broken. If broken, replace with new plastic power button. Rebuild device by doing steps 1-8 in reverse order and see if your power button is working. If the device still does not turn on, follow steps 1-8 and skip this step.
  10. Unbranded UB-15MS10 Power Button Replacement: 步骤 10 中的图像 1,1
    • Unscrew the two 1.2mm screws of this component, which is wired to the motherboard.
  11. Unbranded UB-15MS10 Power Button Replacement: 步骤 11 中的图像 1,1
    • Unscrew the two 1.2mm screws of this component, which is also wired to the motherboard.
  12. Unbranded UB-15MS10 Power Button Replacement: 步骤 12 中的图像 1,1
    • Remove old motherboard from tablet. Take the new motherboard and splice the black wire of the board to the black wire of the battery. Do the same for the white and red wires.
结论
To reassemble your device, follow steps 1-8 and 10-11 in reverse order.
2等其他人完成本指南。
Matthew Sylvia
于03/08/17注册
280 声望
创作了2篇指南
团队
一条评论
Hello,
Do you have a part for the power button or know of a place that would sell them?
Thanks!
John - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 1,669
