跳转到主内容
Unbranded UB-15MS10 Battery Replacement
你所需要的
  1. Unbranded UB-15MS10 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Use an opening tool to pry off the lid of the memory card compartment.
  2. Unbranded UB-15MS10 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the two 1.2 mm screws within the compartment using a Phillips #00 screwdriver.
  3. Unbranded UB-15MS10 Battery Replacement: 步骤 3 中的图像 1,2 Unbranded UB-15MS10 Battery Replacement: 步骤 3 中的图像 2,2
    • Insert opening tools to partially pry open the cover.
  4. Unbranded UB-15MS10 Battery Replacement: 步骤 4 中的图像 1,1
    • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
  5. Unbranded UB-15MS10 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the tape that is holding the battery in place.
  6. Unbranded UB-15MS10 Battery Replacement: 步骤 6 中的图像 1,1
    • Cut the wires connecting the battery to the device using a pair of wire cutters.
  7. Unbranded UB-15MS10 Battery Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the battery, making sure that all wires are disconnected.
  8. Unbranded UB-15MS10 Battery Replacement: 步骤 8 中的图像 1,1
    • Splice the new battery with the red, white, and black wires connected to the motherboard.
结论
To reassemble your device, follow directions 1-7 in reverse order.
3等其他人完成本指南。
Evan Peterson
于03/08/17注册
320 声望
创作了2篇指南
团队
一条评论
No wonder this tablet was not a big success for Best Buy. Cutting the battery cables has to be an engineering nightmare. It makes no sense to solder something like a battery to the motherboard knowing fully well it has to be replaced in the near future. The engineer that designed this hopefully is in the unemployment line.
Milton Carroll - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 2,267
